It wont turn on - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: It wont turn on
    Points: 19, Level: 1
    Level completed: 37%, Points required for next Level: 31
    Onyxceptable is on a distinguished road
    Aug 2011
    It wont turn on
    While charging my phone, I was browsing Facebook. Well, While loading the page, my screen went black and turned off. Now it won't turn on, I've tried texting it, calling it, Removing it from the power source, and removing the battery. And nothing. Please help.
    Points: 26,480, Level: 71
    Level completed: 24%, Points required for next Level: 570
    Overall activity: 96.0%
    Can you get the phone into recovery mode, Volume up + Home + power, if you can get into recovery then you can do a wipe data/factory reset. It will wipe all your accounts and any apps you have downloaded but may well sort out the problem you have.
    Points: 53,785, Level: 100
    Try removing the battery for 5 minutes before putting back in.
