Upgrade for Samsung Galaxy fit GT S5670 - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Upgrade for Samsung Galaxy fit GT S5670
    Points: 124, Level: 2
    Level completed: 48%, Points required for next Level: 26
    Overall activity: 48.0%
    Tagger Second Class100 Experience Points
    Aug 2011
    Is there an official Samsung firmware update for Samsung Galaxy fit GT S5670.
    Here are the details of my phone:-
    1/Model : Samsung GT-S5670
    2/Android version : 2.2.1
    3/Baseband version:S5670JXKA4
    4/Kernel version: 2.6.32.9-perf/ root@SE-S508#1
    5/Build number: FROYO. JPKC1
    6/ My phone is already rooted.
    In the affirmative, where can I find/download it please.
    Would highly appreciate any help.
    TIA
    Points: 27,048, Level: 71
    Array Doomed's Avatar
    Try looking at www.samfirmware.com. You'll need to sign up.
    Make sure you download the correct firmware for your phone and read the guide on how to flash your phone from there too.
    Latest update for a European phone is Android 2.3.4
    Hidden Content
    Aug 2011
    Quote Originally Posted by Doomed View Post
    Try looking at . You'll need to sign up.
    Went to samfirmware.com and found that there is only one Arabic firmware :- S5670JPKC1 ## CSC_S5670OJPKC1 2.2.1 2011 March.
    This firmware is already installed on my phone.
    However,there are three other Android 2.3.4 firmwares for my Galaxy S5670 but for different regions from the one already installed in my phone(Arabic). these firmwares are:
    S5670XXKPG ## CSC = SERKPG 2.3.4 2011 May 25
    S5670XXKPI ## CSC = SERKPI 2.3.4 2011 June 2
    S5670XWKQ2 ## CSC = OXXKQ2 2.3.4 2011 June 29
    I have three questions:
    1/ Are these firmware official Samsung firmwares ?
    2/ Is it possibile to install one of the three mentioned firmware above considering my original firmware is Arabic.
    3/ If yes which one shoud I choose to install.
    Regards
    1) I believe they are leaked firmwares
    2) Depends if there is a difference between hardware, software for your network frequency's. Also the other firmwares may not have Arabic Language.
    3) None if you already have the latest one for your region. Not unless your willing to lose your phone.
    Hidden Content
    Aug 2011
    Thanks a lot for your advice.
    Regrds
