[SGS II Rom] Firmware I9100XXKG6 2.3.4 (GINGERBREAD) for Samsung Galaxy I9100 - Samsung Galaxy S Forums : Galaxy S2 S II Forum - Page 2
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Firmware I9100XXKG6 2.3.4 (GINGERBREAD) for Samsung Galaxy I9100
  1. #11
    Points: 3,637, Level: 25
    Level completed: 35%, Points required for next Level: 163
    Tagger Second Class100 Experience PointsTagger First Class7 days registered250 Experience Points
    LisaUK is on a distinguished road LisaUK's Avatar
    Thanks for your help and quick reply DSA! :-) I'll flash this when I get home ( I have Chainfire's KG6 rooting kernel already downloaded too).
    Lisa
    ROM Modder
    Points: 2,494, Level: 20
    Level completed: 72%, Points required for next Level: 56
    Overall activity: 56.0%
    DSA is a jewel in the rough DSA is a jewel in the rough DSA is a jewel in the rough DSA's Avatar
    no worries, happy flashing
  4. The Following User Says Thank You to DSA For This Useful Post:
    LisaUK (08-13-2011)
  5. #13
    Excellent! firmware updated and rooted, Skype video supported
  6. #14
    Has anyone had GPS problems with some apps using this firmware? I've noticed problems with Open Wifi Scanner and Wifi Radar where the pointer for wifi location points in the complete opposite direction (i.e. 180 degrees away). The GPS appears to be okay with Google Maps etc, although it has jumped around occasionally.
  7. #15
    Points: 608, Level: 9
    Level completed: 8%, Points required for next Level: 92
    Tagger Second Class7 days registeredTagger First Class100 Experience Points250 Experience Points
    arda is on a distinguished road
    Aug 2011
    Hi Guys,
    I am not sure if anyone is experiencing the same as what I have but when I upgrade mine from 2.3.3 to 2.3.4 KG6, when I receive skype call it does not ring. I can see that there is an in-coming call but it does not give the ringing sound. I have checked all the sound and volume settings but no result. so at the end I re-flash i back to 2.3.3 KG2 and all kind of back to normal. The origin of my phone is HK and when I re-flashed it using the same stock firmware KG2 my keis does not allow it to pull any update. do I need a specific firmware for this?
    I thought bu using KG2 (stock) it will return it to the factory firmware but it does not seems to be the case.
    any suggestions or link where I can get the original KG2 firmware 2.3.3 will be much appreciated.
