[SGS II] samsung galaxy s 2 auto shutdown problem - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 19
Thread: samsung galaxy s 2 auto shutdown problem
    Points: 41, Level: 1
    Level completed: 82%, Points required for next Level: 9
    Overall activity: 23.0%
    Angry samsung galaxy s 2 auto shutdown problem
    hi guys
    i had bought sgs 2 about 3 weeks ago..it worked very nice but after 2 week it start automatically shut down at least thrice a day.... i also went to samsung costumer center they format my OS and reinstall it... but does effect much now it automatically shut down twice a day what should i do is it a software or hardware problem....pls help me what should i do??????
    Points: 215, Level: 4
    Level completed: 30%, Points required for next Level: 35
    Tagger Second Class7 days registered31 days registered100 Experience Points
    Go to the Android Market and install Load Monitor. Open it up, go into Preferences and tick 'Wake Lock'. See if that helps
    thxs bro i will try it...
    Points: 1,598, Level: 16
    Level completed: 24%, Points required for next Level: 152
    I had the same problem but since updating to KE7 have had no problems
    Quote Originally Posted by braudrist View Post
    sorry bro no effect it still shut downing....
    Quote Originally Posted by ming View Post
    bro it is already update to KE8.....what should do now......
    Points: 357, Level: 6
    Level completed: 57%, Points required for next Level: 43
    Overall activity: 11.0%
    Wales, UK
    Top of my list would be a badly behaving app - or your phone is faulty.
    I suggest you remove ALL applications that you have installed. If the problem goes away, reinstall your apps one at a time until you discover the rogue app.
    If the phone is still misbehaving after that return it for a replacement.
    Points: 1,728, Level: 16
    Level completed: 89%, Points required for next Level: 22
    7 days registered100 Experience Points31 days registeredTagger Second Class250 Experience Points
    Is the Location service active in your phone, and the actual location you're in is NOT recognized by Google maps (like no address, etc.)? If so, deactivate the service and see if it helps...
    Quote Originally Posted by MoldCAD View Post
    thx bro i wil try it..
    Quote Originally Posted by dck View Post
    thx bro i have done tht(removing apps) but no use.... replacement is my last step....
