[SGS II] Error Messages when Charging Battery - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Error Messages when Charging Battery
    Points: 864, Level: 11
    Level completed: 43%, Points required for next Level: 86
    i got my SGS2 just yeaterday and i cant put it down. obviously the battery run down. when i try charging it i keep getting "battery disconnected" messages. the battery charges for a while and then i get the disconnect message. after a while it resumes charging without any interference. someone please help.
    Points: 15, Level: 1
    Level completed: 29%, Points required for next Level: 35
    Aug 2011
    Hi cassi,
    I got the same errors after installing an sd card in my SGS2. I removed the SD card and the error went away. It almost looked as if the sd card stuck out farther than the plastic around the battery, possibly pushing down on the battery?
    So when installing the SD card for the second time I ensured both it and the battery were pressed in and seated correctly. Especially that the battery was making good contact with all the pins on the phone. That seemed to work as I no longer get the error anymore. Although it all seems a little too odd to me, but hopefully it will stay error free and charge the battery now.
    Hope this can help some.
