Really strange problem - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Really strange problem
    Points: 701, Level: 10
    Level completed: 1%, Points required for next Level: 99
    Overall activity: 36.0%
    ohmikey is on a distinguished road
    Hello all.
    I have a rubber/silicone case on my phone, it does not touch the screen, only the back and sides.
    My touchscreen works fine, BUT when I make a phone call the screen blacks out and the screen does not work/respond AT ALL, neither does the side buttons...heres the weird part, If I peel back just the top of the skin (off the top side of handset) the touchscreen works again!!!
    Any one got any ideas?!
    Points: 7,764, Level: 37
    Level completed: 79%, Points required for next Level: 86
    hazi1964 is a jewel in the rough hazi1964 is a jewel in the rough hazi1964 is a jewel in the rough hazi1964's Avatar
    Bournemouth, UK
    I have the same type of cover on mine and have never had any issues.
    Alison
    I will try and get a video up
    Points: 776, Level: 10
    Level completed: 76%, Points required for next Level: 24
    Your first GroupTagger Second Class100 Experience Points7 days registered250 Experience Points
    jonny blond is on a distinguished road jonny blond's Avatar
    Mar 2011
    Northwest UK
    Quote Originally Posted by ohmikey View Post
    Hello all.
    Its probably covering the light sensor on the top of the phone. its about 8mm right of the front camera.
    It wouyld seem there is a sensor on top, I can freeze the screen during a call with my finger on top also.
    Thanks Johnny, i was typing as you were
    Points: 13, Level: 1
    Level completed: 25%, Points required for next Level: 37
    maxdd is on a distinguished road
    Probably it's the proximity sensor which turn off your LCD while calling...check in Settings>calls you can disable it... havent tried yet anyway...
    Thanks, that worked! Do I need the LCD on?
