[SGSII Custom Rom] Data network mode will not activate? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Data network mode will not activate?
    Points: 171, Level: 3
    Level completed: 43%, Points required for next Level: 29
    Overall activity: 12.0%
    Tagger Second Class100 Experience Points7 days registered
    Hi all, I installed the lite'ning rom around 4 days ago but since yesterday I'm unable to activate data network mode? It's ticked under the settings and i've tried turning it on and off but it still doesn't come on. When I hold the power button it will say its activated but if I wait 30 seconds it switches to saying its deactivated? Is this a problem with the rom? Thanks.
    Well I think I figured it out (no thanks to you lot :P). If wifi is on then mobile data is automatically turned off even if you're not connected to a network?! What an annoying feature thats not made aware of! Hope it helps for anyone with the same problem.
    If wifi isn't connected mobile data comes on here. I don't have to switch off wifi for it to work, did you toggle mobile data off maybe?
    False alarm, it just works when it wants. Goes on and off all the time. Gonna put it back to the original vodafone firmware. I have mobile data on yeah.
