[SGS II] overheating problems - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 11
Thread: overheating problems
    Points: 167, Level: 3
    Level completed: 34%, Points required for next Level: 33
    Overall activity: 10.0%
    Tagger Second Class7 days registered100 Experience Points31 days registered
    philippos is on a distinguished road
    Dear All,
    i have the galaxy s2 which is perfect.
    i have some problems though:
    when i charge the phone or use some applications, it gets hot. also the battery does not last.
    please let me know your comments in order to know if i shall return it or if its how it is.
    thanx
    Points: 20,655, Level: 62
    Level completed: 70%, Points required for next Level: 195
    Overall activity: 92.0%
    Some threads about this on the forum.
    1st step, try updating your firmware, this seems to be a problem on some firmwares
    2nd, If that don't work and nobody else has helped I'd return the phone
    thank you very much.
    i am returning it...
    Points: 20, Level: 1
    Level completed: 39%, Points required for next Level: 30
    Nomad025 is on a distinguished road
    Hello,
    i have bought yesterday galaxy s II.
    I got same problems, overheating and the battery doesn`t last for long.
    I have extreme overheating when playing Real Football HD for 5 mins.
    What were your sypmtops, philippos ??
    Note: My FW version is actual.
    Thanks a lot
    Dear nomad,
    i returned the phone and they replaced.
    now i am waiting for new firmware and android 2.4
    dont push it a lot cause on the previous one the screen lost its darkness
    Dear nomad,
    Dear philippos ,
    what about the replaced phone, you received?
    Everything ok?
    Smaller overheating and battery last longer?
    Nomad
    Dear Nomad,
    he replacent is much better. the firmware is gingerbread.xwke7 and on previous was (if i remeber correctly ke4).
    the batter is better (48 hours) and the overheating problems are almost gone.
    i have turned off location services and 3g(open it whenever i want) and dont play games with high graphics.
    I see....can i ask you, i have buyed the phone only this week on wendesday. Should i wait with replacement a few days, and see what will happen?
    How long do you wait with replacement?
