[SGS II] Clock problem - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Clock problem
    Points: 1,646, Level: 16
    Level completed: 48%, Points required for next Level: 104
    7 days registeredTagger Second Class31 days registered100 Experience Points250 Experience Points
    Array LloydB's Avatar
    Luton
    Clock problem
    This a basic problem Im sure I just do not know why it keeps doing this, my clock i have on my home screen which is just the stock digital clock from the widget keeps freezing, it just sticks on certain times during the day, why will it do this and what am I not doing right...?
    LloydB
    Points: 60,876, Level: 100
    Array Richardj's Avatar
    Try deleting from you home screen, press and hold on it and drag it down to the bottom, when the recycle bin shows let it go. Reboot your phone and then add it to your home screen again. It might help.
    Samsung Galaxy SII GT-I9100. Stock Jelly Bean 4.2.2, Rooted. MoreFine S6 Pro, Jelly Bean 4.2.2, rooted with framaroot.
    Administrator Array Briggs's Avatar
    Spain
    Are you using the task manager to kill apps or clear memory? That would be the case. Personal I recommend Go Launcher Ex and then I lock fancy widget for example to stop it being killed off.
    Hidden Content | Hidden Content
    Points: 328, Level: 6
    Level completed: 28%, Points required for next Level: 72
    Tagger Second Class7 days registered100 Experience Points31 days registered3 months registered
    It stops when you use 'clear ram' try it...is one of a few niggle I to have with the software on the SG2
    Red
    Luton
    Thank you for answers, yes it is when I clear RAM, yet the dual analogue I have on 2nd screen is not affected at all, (yes more than 1 clock, i have interest in different time zones)just dont like an analogue on main home screen as my time piece, I will try Go launcher Ex, thank you Briggs. Also is using Task manager to kill apps and memory / clear Ram necessary...? I do it usually after everytime I have a little play on the phone, thinking Im keeping the phone at its optimum,am I just being naive, im not technically minded and tbh do not have a clue what half the stuff is :P
