Is there a blinking light alert ? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 16
Thread: Is there a blinking light alert ?
    Points: 146, Level: 2
    Level completed: 92%, Points required for next Level: 4
    Overall activity: 11.0%
    I am used to have a blinking light alert in case of a missed call, also a mail, sms or even a whatsapp message with my previous Motorola Droid. I even could arrange different colors to different situations. I could not find this in SII and I really miss it ! Is there a way to make it possible ?
    Points: 1,248, Level: 13
    Overall activity: 17.0%
    Tagger Second Class100 Experience PointsTagger First Class250 Experience PointsOverdrive
    I used to have this on my N900 and also missed it. The closest I've found is called NoLED. It will blink a few pixels on your screen which are entirely customisable, so you could say missed call shows up red. Because of the nature of AMOLED, it only uses up power for those few pixels so it's not a massive battery hog.
    I've also set mine to vibrate every 5 minutes that I don't unlock the phone when I have a missed [call, email, message, etc], which is another option in NoLED.
  4. The Following 2 Users Say Thank You to llBlackenedll For This Useful Post:
    kradcliffe (05-18-2011), stonkr (05-12-2011)
  5. #3
    Stupid Modulator
    Points: 17,492, Level: 57
    Level completed: 57%, Points required for next Level: 258
    Array stonkr's Avatar
    1+ Forums
    I've been using Easy Reminder but I don't think it works all the time. I'll give this a go instead.
    EDIT: Love this app, very useful, good recommendation.
    OnePlus One : Galaxy Tab2 10.1
    Quote Originally Posted by llBlackenedll View Post
    Is NoLED only for missed calls ? Or does it also notify for missed messages and so forth ?
  8. #5
    Quote Originally Posted by Teoman View Post
    You can use it for virtually everything that gives out notifications I believe, including all your examples.
  9. #6
    Points: 152, Level: 3
    Level completed: 4%, Points required for next Level: 48
    Tagger Second Class7 days registered31 days registered100 Experience Points
    Excellent App, great recommendation. Thanks
  10. #7
    Points: 1,931, Level: 17
    Level completed: 91%, Points required for next Level: 19
    7 days registeredTagger Second Class100 Experience Points31 days registered3 months registered
    Array kradcliffe's Avatar
    Excellent, just what I've been looking for!
    Keith
  11. #8
    Points: 24, Level: 1
    Level completed: 47%, Points required for next Level: 26
    I've been doing some testing. My S2 idles losing at about 1% an hour. With NoLED on it loses about 12% an hour (if it's continuously showing a notification). If I set it to dim the screen about 10% an hour. If I set to blink still about 10%. I'm fine with those numbers since I'll generally catch a notification with-in maybe 10 mins.
  12. #9
    Quote Originally Posted by Ames View Post
    That's really weird because my phone doesn't even use 10% an hour if the screen's on.. do you have it set to vibrate at regular intervals too, that may cause some of the drainage?
  13. #10
    No vibrate. The phone wasn't really doing much of anything. The 1% per hour with NoLed off seemed pretty good.
  14. Remove Advertisements
