[SGS] Have I the best firmware? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Have I the best firmware?
    Points: 54, Level: 1
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 30.0%
    Hi since changing some settings on the phone (S1) it would not boot past the samsung logo screen, doh!!
    Found a site on google with instructions on how to flash. I now how this version installed:
    Baseband: I9000XXJVK
    FIRMWARE VERSION 2.3.3
    BUILB: GINGERBREAD.XWJVB
    Is this version ok does it need updating again or is it ok to leave alone now?
    oh tried keys and it said this version can not be updated????????
    Points: 25,725, Level: 70
    Level completed: 18%, Points required for next Level: 575
    Array Richardj's Avatar
    2.3.3 Gingerbread is the latest, but are for the Scandinavian countries. Some UK phones have been lucky enough to get the UK version from kies before Samsung withdrew it because of some problems. I don't know where you got it from but you might want to look at samfirmware.com. You will need to register on the site, it's free.
    MoreFine S6 Pro, Jelly Bean 4.2.2, rooted with framaroot. Vernee Apollo X, Marshmallow 6.0 Decacore
    That is the site I got the firmware from, on the Europe list near the bottom.
    What should be the latest firmware that Kies would recognize from that site?
    Thank you.
    Points: 994, Level: 12
    Level completed: 30%, Points required for next Level: 106
    Overall activity: 26.0%
    7 days registered31 days registeredTagger Second Class100 Experience Points250 Experience Points
    The latest UK version (XEU) is JPY 2.2.1 if you decide you want to go to a UK version you may want to flash JPO before you flash JPY.
    I will have ago at flashing with jpo, should I just then let kies update the phone?
    Thanks for your help.
    Points: 1,954, Level: 18
    Level completed: 2%, Points required for next Level: 196
    If you can get Kies working and you don't want to go down the custom rom route then yeah, Kies is the easiest, least stressful way! Odin is fine after you've used it for the first time, but that first time is bum clenching
    Quote Originally Posted by biccys View Post
    Used odin yesterday and was nervous, I want to get a firmware installed so kies can take over again.
    Downloaded I9000XXJPO but none of the files are PHONE, PDA or CSC. the files after unzipping are factoryfs, param, cache & few others.
    Not sure what to do with these files?
    Ok kies just updated the phone to
    Baseband: I9000XXJVO
    BUILB: GINGERBREAD.XWJVH
    Is this uk version, i am lost now should I just leave it alone now and lets kies look after all updates?
    thanks.
    Quote Originally Posted by WACMAN View Post
    thanks.
    Where abouts are you, UK or some where else
    Try this and post back what you find: You will need to know your phones IMEI number first, to find it *#06# in the dial pad, write it down, then enter this into the dial pad *#272*your IMEI Number# it should look some thing like this *#272*347275984764583# This will tell you what sales code you have, If UK it will be XEU, XEE is for Scandinavian countries.
    Quote Originally Posted by Richardj View Post
    sales code is XEE
    I an in the uk and phone bought from Car Phone Warehouse.
    cheers
