Battery issue after update - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Battery issue after update
    Points: 5,113, Level: 30
    Level completed: 38%, Points required for next Level: 187
    Overall activity: 99.6%
    Tagger Second Class1000 Experience Points500 Experience Points250 Experience Points100 Experience Points
    HI My battery is only lasting 12 hours or less with Minimum use after the OS upgrade to 6.0.1
    some one has said to do a master reset? is this another name for a hard reset? to solve this problem
    My phone goes away for repair in a few days regarding this battery issue but I was just wondering if this was true
    thanks
    Points: 67,433, Level: 100
    The tern used is "factory reset" which realigns all files to the default ROM settings.
    It should always be done after a major update and also consider that a few days are required after this for the system to re-index itself and settle down.
    In short, immediate higher battery use after an update is not uncommon and neither is it a fault.
    Thank you
