Screen problem then not charging - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Screen problem then not charging
    Points: 63, Level: 1
    Level completed: 26%, Points required for next Level: 37
    Overall activity: 98.0%
    Mar 2017
    I'm using Samsung s5 for more than 2 years. Everything was fine until my screen started to work not properly. My screen always stays black, then I press button on the left side to unlock my phone, screen turns on for 1s ant then screen is black again. I thought maybe my screen is broken or something, but then I connect to charge after 2 min everything is fine, I can disconnect and use it properly, screen works fine. Then I lock my screen, after 10-15min, problem returns. Does anyone had this problem?
    Points: 67,433, Level: 100
    Do you have any apps that might be interfering?
    Battery saving apps or any others that can control lockscreen?
    Mar 2017
    i'm using only default samsung s5 apps.
    Probably worth backing up and doing a factory reset to see if there is a conflict somewhere.
    Mar 2017
    that's what I will do. I will let you know when I have more information.
    Points: 800, Level: 10
    Level completed: 40%, Points required for next Level: 150
    Overall activity: 86.0%
    7 days registered31 days registeredTagger Second Class3 months registered1 year registered
    Mar 2016
    Have you dropped your device in water or you sweat much??
