Did you create the 2nd partition > 2gb? If you did, please make it smaller than 2gb. From what I had read, that is causing problem.
Do a mount command to confirm your 2nd SD card is properly mounted. If it didn't get automount, then something maybe wrong with the 2nd partition. You may need to format again.
EDIT: From what I read, it seems, > 1gb for 2nd partition would be a waste of space. I only set as 1gb.
