Hi all.i have just rooted my phone with one click superuser.i then installed ryan za's oclf and installed lookout mobile security app.are there any other apps or easy things i can do to further improve what is now becomeing a very fast working phone.any good combination of apps or something as easy as rooting.thanks all.
I was using a task killer aswell but there is an option in oclf that behaves the same way as a task killer(so it says).would there be any benefit to using a task killer aswell.
