Need 2e kernel... - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Need 2e kernel...
    Points: 1,096, Level: 12
    Level completed: 98%, Points required for next Level: 4
    7 days registered100 Experience Points31 days registeredTagger Second Class250 Experience Points
    myk318 is on a distinguished road
    Need 2e kernel...
    Good day,
    I was able to root my phone using z4root...
    And i was phone is capable of the 3 button combo (recovery mode).
    But my kernel is still 3e since i'm on froyo 2.2
    how can i change my kernel to 2e?
    hope anyone can help.
    Thanks!
    Points: 396, Level: 6
    Level completed: 96%, Points required for next Level: 4
    chotto69 is on a distinguished road
    you can flash CF-Root Kernel: http://forum.xda-developers.com/showthread.php?t=788108
    It worked for me
    Quote Originally Posted by chotto69 View Post
    It worked for me
    Thanks!
    I have JP8? which filename do I use?
    Quote Originally Posted by myk318 View Post
    Thanks!
    I don't think there's a huge difference (it's said so in that post too): if you want to play safe use one that's closer to your version: either JP6 or JPA.
    Or you could flash JPY (or install it with Kies as I did) which is basically a froyo updated (2.2.1) but much, MUCH faster and smoother. Then you could flash the exact kernel JPY.
    But if you are thinking to switch to a custom rom (such as the awesome Darky's) and you are getting 2e just for that, I wouldn't go through all this trouble but only pick any kernel.
    I hope this helps
    Thanks for the help..shall try JP6..
    I hope this helps
    Thanks for the help..i shall try JP6...
