USB suddenly not recognised - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: USB suddenly not recognised
    Points: 405, Level: 7
    Level completed: 5%, Points required for next Level: 95
    jaffa1980 is on a distinguished road
    Hi all,
    I have had the phone for a while and am generally happy with it, however I had to put the phone into debug mode the other day (which worked fine) but since then I cannot connect to the pc... I dont even hear the 'ding dong' lol.
    I have windows vista 64.
    On a plus note I have FINALY got kies to get past the 'cannot run uninstaller' lol so have kies but cannot connect... hmmm.
    I'm pretty sure I have done something daft but can't for the life of me think what! any help would be great!
    Points: 53,660, Level: 100
    My USB ports like to work when they feel like it. Some days they can only be slightly bothered and pretend their USB1 ports. I would say be kind to your USB ports and make them feel wanted. They might start working then.
    If the above isn't to your liking, although true in parts, then try removing the usb drivers and re-installing. Try different USB ports. Kies will not work while in USB Debug mode.
    Hey just to let you know that didnt work, tried using different USB, then uninstalled them all and re installed (after rebooting), have now also tried full factory reset with format of internal card... gutted!! lmao just my luck too! course cant use odin either as dont connect to the pc except for charging... confused!!!
    When I had trouble with connecting in the usual way, having the phone in debug mode and connecting to Odin still worked. Joking aside sometimes it's just a matter of time. My PC honestly thinks I have USB1 ports sometimes when hooking up my SGS, also says that it has found new hardware but used it for last 3 months.
    Points: 20,686, Level: 62
    Level completed: 75%, Points required for next Level: 164
    Overall activity: 99.7%
    Have you tried something else in your computers USB ports and see if that works.
    Try re-installing the driver software from microsoft then re-install the drivers for the Galaxy S
    yeah have got a new usb mouse and printer still works in all ports. Have unintalled and re-installed all drivers.... will try and leave it for a bit and see what happens. Also Odin doesnt work coz even in debug mode the computer doesnt think there is a phone connected (dong ding.... disconnected ding dong) will update if i get anywhere in the mean time please keep sending ideas
    Maybe stupid but have you tried a different cable, as the one your using could be damaged
    Points: 2,172, Level: 19
    Level completed: 11%, Points required for next Level: 178
    Overall activity: 12.0%
    SCP is on a distinguished road
    Sheffield - Steel City
    Quote Originally Posted by jaffa1980 View Post
    Hi all,
    I find that plugging into usb and while plugged in then turn phone off then on (leaving cable in). Usualy sorts mine out. Thany or use a nojkia supplied micro usb as i have never had problems with that one lol
    SCP
