A way to center widgets? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: A way to center widgets?
    Points: 743, Level: 10
    Level completed: 44%, Points required for next Level: 57
    Tagger Second Class100 Experience PointsTagger First Class7 days registered250 Experience Points
    Habylab is on a distinguished road
    I love beautiful widgets, but on LauncherPro, its really high up for no real reason annoyingly. Is there a way to center it, as it seems quite high up in its 'grid'. Thanks!
    Points: 20,669, Level: 62
    Level completed: 73%, Points required for next Level: 181
    Overall activity: 99.7%
    Can you provide a screen shot or explain abit better what you mean as I use this and don't have that problem.
    Quote Originally Posted by Doomed View Post
    Basically, on my main home screen, I have the Home Weather icon from beautiful widgets, and compared to using TouchWiz, the widget is high up, closer to the status bar. Its weird, and annoying. Does that explain it enough? I will screenshot it if you need more clarification.
    Points: 2,397, Level: 20
    Level completed: 24%, Points required for next Level: 153
    steviweavi has a spectacular aura about steviweavi has a spectacular aura about steviweavi has a spectacular aura about
    France
    Quote Originally Posted by Habylab View Post
    and you can't just simply move it?
    Quote Originally Posted by steviweavi View Post
    No, it takes up 2x4 and is in the top 2 rows.
    Points: 1,211, Level: 13
    Level completed: 74%, Points required for next Level: 39
    Papi French is on a distinguished road
    France
    Hi Habylab
    Can you not move the widgets below temporarily off the screen, then just drag the widget lower down, then replace the widgets that you moved, maybe a stupid answer, but try it anyway.
