Problem sending text messages using handcent app - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Problem sending text messages using handcent app
    Junior Member Achievements:
    Pulse 14 is on a distinguished road
    Hi
    I haven't had my galaxy for very long at all, only like two days. I downloaded the handcent messaging app for my phone straight away because I know people who use it and it looked really good. Its been working fine until now. I've tried sending several texts and they wont send. I get a red circle with a cross in it next to the message and up on the bar at the top of the screen that has the battery etc on it, there is t markhe message sign with an exclamation mark on it.
    if anyone has experienced this problem or have any ideas what I can do to get it working again I would really appreciate it.
    fake Mọderator
    Points: 31,311, Level: 77
    Teh USA
    never used the app, but if you want to be able to send messages again, you could always uninstall that messaging app
    .____________...___________./l、
    ...add me [= .......____________...(゚、 。 7
    .......h3artlessjerk@hotmail.com .  l、 ~ヽ
    .............._______________............... じしf_, )ノ
    Points: 24, Level: 1
    Level completed: 47%, Points required for next Level: 26
    Overall activity: 9.0%
    jacksonwalt is on a distinguished road
    I also never use this application but i heard about problem in sending SMS from Samsung Galaxy LTE when uses Rogers LTE network in Canada.
    Points: 26,222, Level: 70
    Level completed: 89%, Points required for next Level: 78
    Quote Originally Posted by Pulse 14 View Post
    Hi
    Check the phones APN settings: menu>settings>wireless and networks>mobile networks>Access Point Names. Search for the correct settings on your providers website, you should also find instructions on how to enter the settings on there website to.
