GPS just doesn't work properly on Samsung Galaxy S? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: GPS just doesn't work properly on Samsung Galaxy S?
    Points: 1,907, Level: 17
    Level completed: 79%, Points required for next Level: 43
    Overall activity: 2.0%
    The North, UK
    I have my new Samsung Galaxy S from Orange UK and the GPS features just don't work properly. It's been pretty cloudy the last few days but even so I can get GPS position on my old HTC Touch HD and my firend has no problem with his HTC Desire. The SGS though just will not achieve GPS lock or at least won't maintain lock, when using Google Maps for example.
    I have the following settings:
    Firmware: 2.1-updtae1
    Baseband: I9000XXJF3
    Kernel: 2.6.29 umts_scm@S1-BUILD05#02
    If it can't manage this - it's going back..
    Oddly - when I use an app like "GPS TEST" it shows that it is picking up satellites and seeming to work out where I am..
    Any one else have these problems, anyhelp would be much appreciated,
    AAA
    fake Mọderator
    Points: 31,311, Level: 77
    Array soraxd's Avatar
    Teh USA
    the gps on this phone sucks.. were all hoping for a fix but we dont have one yet
    Hidden Content .____________...___________./l、
    ...add me [= .......____________...(゚、 。 7
    .......Hidden Content .  l、 ~ヽ
    .............._______________............... じしf_, )ノ
    Points: 15,015, Level: 53
    Array tiptronic's Avatar
    Bristol, UK
    I too having the same problem with GPS while using Co-Pilot in town. It loses the satellite so easy, keeps re-detecting position on nearly every single corner.
    Network: O2 UK
    Baseband version: I9100XXLPQ
    Points: 3,807, Level: 26
    Level completed: 3%, Points required for next Level: 293
    7 days registered100 Experience Points250 Experience Points500 Experience Points31 days registered
    Co pilot seems fine to me these days,and google maps will lock indoors to within one house or 2. I had a lot of trouble on jf3 but jfb and jg1 have been fine for me. I have yet to drive through anywhere with loads of tall buildings but rainy days and driving through tree cover seems fine.
    Points: 7,890, Level: 38
    Level completed: 10%, Points required for next Level: 360
    100 Experience PointsTagger Second Class7 days registered250 Experience Points500 Experience Points
    Array someuser's Avatar
    Adelaide South Australia
    Quote Originally Posted by sammy View Post
    Count me as a user that has no problems with the GPS. It's actually better than my Iphone 3G was but I'm pretty sure it had a hardware fault. I must admit though, I am a GPS device junkie and own 5 GPS units (Garmin Nuvi 250, Garmin Nuvi 500, Garmin GPSMAP 60cx, Tom Tom One XL, GPSMAP 276C) so the phone only gets used for google maps now and then :-D
    Points: 924, Level: 11
    Level completed: 83%, Points required for next Level: 26
    Overall activity: 1.0%
    Yep I'm loses gps quite easily as well
    The North, UK
    jf3? jfb and Jg1? are these all homebrew ROMs or official updates? So you think that you have better response with these?
    I went down the homebrew route with my old HTC HD to good effect - but only after I was bored with it and the ROMs 'stabilised' - I don't know that I want to do that yet on my SGS. Especially as I'm still inside the 7 day return period and I'm not sure I can live with this..
    I considered buying co-pilot as I figured it might be the SGS interaction with Google's software that is the problem.. But there's no trial version so it would mean a £25 ish investment to potentially find that it doesn't work either..
    There was at least one web review that said it worked fine with sat nav but not with Google navigate..
    Hmm.
    Quote Originally Posted by AAA View Post
    Hmm.
    These are samsung firmwares not home brews. while the custom roms on galaxy s are good they do nothing to aid gps. It might be a case that all i needed was a factory reset on jf3 but i never tried it and just flashed firmware instead.
    Administrator Array Briggs's Avatar
    Spain
    I tested the GPS today driving to work and no issues with Sygic GPS. Lock 100% of the time and 5 bars. All good my side.
    Hidden Content | Hidden Content
    The North, UK
    Quote Originally Posted by Briggs View Post
    Hi - are you using Jf3 or JF5 firmware? If there is an update to my JF3 firmware that will help - how come Kies tells me there is no update available when I try? Have Orange locked this so it won't update?
    Any advice much appreciated..
