Launcher Pro - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 19
Thread: Launcher Pro
    Points: 9,985, Level: 43
    Level completed: 8%, Points required for next Level: 415
    Overall activity: 99.5%
    Tagger Second Class7 days registered100 Experience Points250 Experience PointsTagger First Class
    Swipermusic is just really nice Swipermusic is just really nice Swipermusic is just really nice Swipermusic is just really nice Swipermusic is just really nice Swipermusic's Avatar
    Solihull
    Launcher Pro
    Downloaded launcher pro yesterday (not sure if I like it yet) and thought I would use it for a couple of days to see what I think.
    The problem is everytime I set it to "set default" using home switcher (it wouldnt launch without that) it sets then as soon as I press the home button it goes back to TWlauncher as default.
    Anyone know why?
    SGSIII
    Unlocked
    O2 Rooted
    Points: 15,015, Level: 53
    tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic has much to be proud of tiptronic's Avatar
    Bristol, UK
    How about set it manually instead of using Home Switcher? If you go menu > settings > applications > Manage Applications > select "All" tab > TWLauncher > Clear defaults. Then press home once and it should load up launcher selector, select Launcher Pro and check "use by default for this action". This work for me.
    Network: O2 UK
    Baseband version: I9100XXLPQ
    Points: 2,699, Level: 21
    Level completed: 60%, Points required for next Level: 101
    edkin03 will become famous soon enough edkin03's Avatar
    Dudley
    Quote Originally Posted by Swipermusic View Post
    Anyone know why?
    i'm quite tempted to try this too, following recent upgrade to Froyo and yes i did do the factory reset after and all is well.
    let me know how you get on with it.
    thanks
    Solihull
    Quote Originally Posted by tiptronic View Post
    Hey Tiptronic! You always have the answer that worked straight away. Will try for a while and let you know how I get on xxx Thanks very much xx
    SGSIII
    Unlocked
    O2 Rooted
    Solihull
    Quote Originally Posted by edkin03 View Post
    thanks
    Will use it for a day or so and report back x
    SGSIII
    Unlocked
    O2 Rooted
    Points: 459, Level: 7
    Level completed: 59%, Points required for next Level: 41
    tobihughes is on a distinguished road
    Please report back , as i have installed this before but couldnt get on with it , now i know my phone a little better would like to give it another go, i read in the comments a lot about Force close , if this is the case i dont want it . would be good to have a running launcher pro link for people to write their thoughts and any problems they have.
    Tobi.
    Bristol, UK
    Glad you have that working, there are some really cool things you can do in Launcher Pro, I will let you work that out yourself for now. Do let me know if you want to know more about LP
    Network: O2 UK
    Solihull
    Right am going to have a good play now and get back to you. Knowing me I will mess something up lol xx
    SGSIII
    Unlocked
    O2 Rooted
    Solihull
    Having a good mess OMG - scrollable glass dock with loads of customisable icons - I am in heaven!
    SGSIII
    Unlocked
    O2 Rooted
    Points: 2,397, Level: 20
    Level completed: 24%, Points required for next Level: 153
    steviweavi has a spectacular aura about steviweavi has a spectacular aura about steviweavi has a spectacular aura about
    France
    mmm..been playing about too..wow I like this
