Device Driver software failing to install for use with Kies problems - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Device Driver software failing to install for use with Kies problems
    Hi , I have recently bought a samsung galaxy and having big problems connecting to Kies.
    So far I have downloaded Kies itself via the samsung website. When I try to connect and plug in my phone using the USB cable I get a message saying device driver software failed to install- does anyone know what this means and how to sort out the problem?
    Many thanks for any help
    Adrian
    What operating system are you running on the PC? Do you have the phone's USB connection in Kies mode when connecting?
    It could be a driver problem on your PC. Have you updated Kies, option in the top left? Have you tried re-installing Kies, turning off the PC after uninstalling the previous version?
    Depending on what system you are running, you may have to download specific drivers?
    Junior Member Array
    I am on Vista, thanks. I will try downloading Kies again and update it as you suggest.
    Cheers
    Z
    Points: 24, Level: 1
    Level completed: 47%, Points required for next Level: 26
    Hi zinc45. Have you resolved this problem?
    I may have a similar problem. My SGS II was working perfect, untill I applied the Kies update that became available Nov 10 2011.
    Now i cant connect my phone. Have unistalled, re-installed, applied the troubleshooter in Kies, all to no avail.
    I use Vista. Anyone pls help.
    Points: 1,382, Level: 14
    Level completed: 88%, Points required for next Level: 18
    Overall activity: 12.0%
    7 days registeredTagger Second Class31 days registered100 Experience PointsTagger First Class
    UK
    I had this in both XP and Windows 7. Never went over to Vista.
    Sometimes its as simple as rebooting the PC with the Phone left connected to the USB. Dont ask me why.
    Otherwise
    http://samsunggalaxysforums.com/show...ny-suggestions
    Loads of fixes here!
    I had to go into device manager and Uninstall the MTP device with the Cross next to it. Unplug phone before leaving device manager. Re-boot. Wait till windows loads. Shut down PC. Plug in phone. turn on PC. Drivers re-install and Kies works. I didnt even DL the Kies Update. I DL'd the drivers for a printer and next time I plugged in the Phone I got errors. Think it must be something to do with how devices are recognised on the USB bus? All beyond me however! Found my Fix by trial and error before I found this forum.
