[HACK] Bypass stock SGS lock pattern for making calls!! - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: [HACK] Bypass stock SGS lock pattern for making calls!!
    an ubuntu/linux geek Array
    Kuwait
    Exclamation [HACK] Bypass stock SGS lock pattern for making calls!!
    Hello there,
    I am glad that it's patched in 2.2, ... well that's what i heard! Anyways' here's what I managed to pull off, a way to bypass the lock pattern of SGS that runs android 2.1 update 1!
    Here's a video of it: http://www.youtube.com/watch?v=ApX8k3P255s
    more blablabla here
    I am not sure about the other versions! Maybe you can help out since all of you are owners of the SGS!
    DO NOT CLICK Hidden Content !!! <--- lol, i always wanned to write that! Dont worry, it's just my blog!
    Points: 10,395, Level: 43
    Level completed: 99%, Points required for next Level: 5
    Overall activity: 13.0%
    7 days registeredTagger Second Class31 days registered100 Experience PointsTagger First Class
    Array Pidz's Avatar
    In the shadows
    LOL - That does indeed work!!! Great find dude! Works on Orange Branded firmware latest (2.1)
    Points: 7,543, Level: 37
    Level completed: 24%, Points required for next Level: 307
    Overall activity: 39.0%
    Tagger Second Class100 Experience Points7 days registered250 Experience Points31 days registered
    Array fatfred's Avatar
    Location Location......AHHHHHHHH!
    Not doing anything on my SGS unbranded/unlocked SGS from CPW!! :<(
    Points: 40,034, Level: 87
    Array Goots's Avatar
    FYI - doesn't work on FroYo JPO
    Points: 640, Level: 9
    Level completed: 40%, Points required for next Level: 60
    Overall activity: 8.0%
    Also not as bad as the iOS hack....at least they can't see all your contacts' info.
    Kuwait
    @fatfred: Mine is also unbranded and unlocked! so far all Im seeing is that it only runs on 2.1, so theoretically, to have this on yours, you should have that firmware version! ... Aand why exactly are you sad?! XD
    @Goots: Yeah! It's really good to know that It's been patched ^^
    @Hampe: There might be a way, but the question is, are you ready to try all the possibilities? XP
    I just hope they change the stock firmware to at least 2.1 update 2!
