For any of you that love the sleek design of the Galaxy S, & don't want to spoil it with a clip on cover. These can be purchased in a variety of colours. Just received a white cover, it fits the phone perfectly, with all clips exactly the same as original, clips on & off the phone perfectly. Description in ad says " Protection for your phone front & rear ", but it is a battery cover so wont protect front. Ad also says " coated with soft water-proof rubber ", but the cover I received was simply white gloss plastic. Ideal if you want to keep the original cover safe in case you want to re-sell your phone in the future.
http://shop.ebay.co.uk/fonemaster-uk....c0.m270.l1313
