Best Way To Clean Your Screen - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Best Way To Clean Your Screen
    Points: 1,207, Level: 13
    Level completed: 72%, Points required for next Level: 43
    Abu Dhabi, UAE
    I've realized that the GSG screen can get dirty and all messy. I know there are screen protectors and all that. I wanted to know from you guys personal experience which way is the best way to clean your SGS screen??
    I've realized that those silky little whipes that u get aren't very effective.
    Points: 7,849, Level: 37
    Level completed: 99%, Points required for next Level: 1
    Array Banjaxed's Avatar
    Out standing in my field
    Talking
    I don't use screen protectors. As far as cleaning my screen goes, I find breathing on the screen and giving it a good rub on my shirt sleeve or anything else that's handy does the trick. Now this method probably wont suit most people but it suits me fine.
    Junior Member Array
    I find that using a cloth for sweeping glasses does a perfect job.
    Points: 10,723, Level: 44
    Level completed: 72%, Points required for next Level: 127
    Tagger Second Class100 Experience Points7 days registered250 Experience Points500 Experience Points
    Array andy-roid's Avatar
    Sheffield, United Kingdom
    As the screen is glass you can use a squirt of window cleaner on a cloth but don't wet through cloth but a lot
    galaxy s3 i9300XXBLG6
    Points: 1,809, Level: 17
    Level completed: 30%, Points required for next Level: 141
    You can buy a proper microfibre cloth from any good optician for about £4. Or in the computer shop you can get one twice the size for the same price for LED screens.
    Administrator Array Briggs's Avatar
    Spain
    Quote Originally Posted by Banjaxed View Post
    Suits me, its exactly what I end up doing most of them time. No screen protectors either...
    Hidden Content | Hidden Content
    Abu Dhabi, UAE
    thanks for the suggestions guys.
    I like the ideas. I think I'm going to try the window cleaner method and see how that goes. I might also buy one of those higher quality microfibre cloths as well.
    cheers
    If you've got a screen protector on lcd tv screen cleaner works well
  11. Remove Advertisements
