Recovery Mode - ADB Shell - No root permission - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 14
Thread: Recovery Mode - ADB Shell - No root permission
    Points: 972, Level: 12
    Level completed: 15%, Points required for next Level: 128
    Hi, I f***ed up my SGS by installing a theme.
    I created a backup of the files, overwritten by the theme.
    The problem is I can not start my SGS anymore.
    So I started into Recovery mode and conntected to the SGS via ADB Shell.
    everything is working there but when I say su I got the error: permission denied.
    And yes my phone is rooted and I also installed apps which needed root permissions.
    How do I get root permissions in the adb shell during recovery mode?
    br
    rizi
    Points: 2,686, Level: 21
    Level completed: 55%, Points required for next Level: 114
    Tagger Second Class100 Experience PointsTagger First Class250 Experience PointsCreated Album pictures
    Mumbai, India
    hey i would suggest u to flash it thru odin
    or if u dont want to do so enter recovery thru 3 button tric n try it
    Quote Originally Posted by abhiraj View Post
    Hi, of course its possible to flash it again with Odin, but all Settings/Apps and so on will be lost.
    So I entered already recovery thru 3 button tric, and in the recovery I conntect with adb to my phone.
    That works great, but I have to overwritte two files in /system/framework and I got permisson denied <-- therefore I want to gain root permissions.
    Is there no way to get root permissions in adb via recovery mode ?
    When my phone was running and I connected via ADB, Ninja asked me if I want to allow root permissions, I clicked Yes, so with a running phone I can get root permissions over ADB, in recovery mode its not possible for me.
    Any suggestions?
    thx
    rizi
    Points: 15,015, Level: 53
    Array tiptronic's Avatar
    Bristol, UK
    Ah, when you say "when I say su I got the error: permission denied." in previous post, I thought you mean as soon as you type "SU", you get access denied.
    Are you on JPK? Samsung has decided to mount /system as read-only, maybe for security purpose. Samsung might not change it back as this is read-only to other android device too.
    If you'll have to change files in /system you've to type the following command to remount /system as read-write:
    busybox mount -o remount,rw /system
    Network: O2 UK
    Baseband version: I9100XXLPQ
    Quote Originally Posted by tiptronic View Post
    I am on JM8.
    I thought I need to have root permissions to remount /system?
    I will try it..
    Thx for the fast reply
    rizi
    Bristol, UK
    I havn't tried JM8, but if you only get access denied when modifying the '/system', chances are it is marked as read-only. If you have not got root access, you will already get access denied message as soon as you type in 'su'.
    Network: O2 UK
    Unfortunately it says busybox not found:
    I did the following
    1) start into recovery mode (Volume Up + Home + Power)
    2) Connected the phone to my laptop
    3)started a command line(in Windows) an navigated to androidSDK/tools
    4)typed: adb shell
    5.)typed: busybox ......
    Busybox could not be found..
    If I connect my phone during its running and do the following:
    2) Connected the phone to my laptop(USB Debugging enabled)
    4)typed: adb shell
    It shows me the parameter of busybox...
    Any ideas, why its not working during recovery mode?
    thx
    rizi
    Bristol, UK
    Try this: After "adb shell", do "su" first before you do the busybox command.
    Network: O2 UK
    Sorry tiptronic, I missunderstand you, because when I am in recovery mode (Home Up + Home + Power) and I type: adb shell, and then su, I got permission denied.
    I also got permission denied when I want to copy something in the /system directory.
    So the question is why do I get permissions denied in the recovery mode???
    Because when my phone is running and i type: adb shell, and then su --> I get the root permission!!
    thx for your help
    rizi
    Bristol, UK
    I am not sure why as I can access to the su while I am in recovery mode, could it be the problem of files in /system/framework? If you still got the update.zip in your internal sd card when you rooted your phone, maybe you can re-apply it again and see if you can gain access to su again? If that still doesn't work, I can only suggest re-flash as I don't think factory reset to help if you can't even reboot your phone.
    ps. I had the same problem while messing with the framework-res.apk for the battery status icons. End up I have to reflash the bloody thing again. Luckly I have everything backup in titanium so it is not so bad for me to reflash.
    Network: O2 UK
