Help needed with predicitive text//sms - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Help needed with predicitive text//sms
    Junior Member Achievements:
    hi there
    i have had predictive text on my phone since i got it a few months ago.
    somehow tonight , i have managed to turn it off OR my 3 year old daughter has.
    I can not figure out how to get it back on.
    Plse can someone help.?
    Also if anyone uses this new texting that's advertised for this phone where u just skim your finger over the screen, plse can you tell me how to get it? and if it is worth getting.
    thank you
    Points: 2,686, Level: 21
    Level completed: 55%, Points required for next Level: 114
    Tagger Second Class100 Experience PointsTagger First Class250 Experience PointsCreated Album pictures
    Mumbai, India
    Just try getting into recovery mode(remove your battery for few mins n after reinserting it press vol up+home ie mid button+ power button till the screen lits up n then realese only power button )
    if not try getting into download mode by doing same procedure as above but with vol down button
    n if u can reply me i will guide u further
    Points: 9,621, Level: 42
    Level completed: 27%, Points required for next Level: 329
    Array DirtySoul's Avatar
    Moldova
    If you mean Swype, then long press the field where you're writing, then select input method. For predictive text, go to settings-locale and text-samsung keyboard-tick XT9.
    Points: 40,034, Level: 87
    Array Goots's Avatar
    Woaahhh!! Hold up there cowboy!!
    No need to go anywhere near recovery mode just to alter a text setting !!
    abhiraj dude, be very careful when giving out advice like that mate.
    From the home screen hit the menubutton (bottom left hand softkey) then select settings.
    Select 'Locale and Text'
    To use Swype, choose 'Select input method' and change to Swype, alternatively to use standard keyboard, select 'Samsung Keypad'.
    You can turn the predictive text on and off in the Samsung Keypad settings on the same page.
  7. The Following User Says Thank You to Goots For This Useful Post:
    abhiraj (09-18-2010)
  8. #5
    Moldova
    Goots, wanted to write something like this about the download and recovery mode, just been too lazy Maybe abhiraj has some other ideas, who knows?
  9. #6
    Question
    thanks so much goots.
    all done!
    very easy when you know how
  10. #7
    Mumbai, India
    Quote Originally Posted by Goots View Post
    hey sory i just interpreted the prob in wrong way got it when read it 2nd time
  11. #8
    Points: 14, Level: 1
    Level completed: 27%, Points required for next Level: 36
    May 2012
    Smile Turn on predictive text.
    to do this, on home page press the menu button (left hand side).
    Select settings
    Select Language and input
    On the keyboards and input methods make sure that goolgle voice typing and Swype settings are not ticked. then tap the icon on the right hand side of Samsung IME.
    You can then select the XT9 setting and any advanced features you wish to use.
