Help with my contacts - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Help with my contacts
    Junior Member Achievements:
    Unhappy Help with my contacts
    New User being thick maybe.....
    when I create a new contact, I can put in the number and then add a second number to the new contact.
    How do I add a second number to an existing contact?
    Points: 40,034, Level: 87
    Array Goots's Avatar
    Go to contacts then select the contact you wish to add the number to.
    Hit the menubutton (bottom left softkey) then click on edit (you might get a warning about being unable to edit sns contacts if you have that particular contact synced with your facebook account - if you do, just acknowledge the warning)
    Now by the existing phone number there is a little green plus sign that has "Add phone number" by it. Click that. It defaults to a home number but you can change it to Mobile, Work, Fax, Pager etc. by clicking on the button that says "Home" on it. Then just tap where it says 'Phone Number' and add the number.
    Remember to hit the Save button to save your changes.
    Thanks Goots
    However, I ain't not got no little green + or any other little green symbol????
    Some more info.
    Just created a new contact, then went back and edited it. This time it's obvious how to add a new number.
    Problem seems to be that I got my contacts from my old phone (unlocked Ericcson from Three mobile) by putting new sim in old phone and copying contacts onto it. It is these contacts which I can't seem to edit properly???
    You could try copying those contacts from the SIM into the phone, then tell it to only display phone contacts.
    I think there are limitations as to what you can do with contacts stored on a SIM. You can't assign pictures to them for example.
