Recommendation for gel case please guys. - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Recommendation for gel case please guys.
    Senior Member clareriley will become famous soon enough clareriley's Avatar
    Stockport UK
    I am using a leather pouch at the moment for the phone, I choose this because I have it in my hand bag alot and past experiences with flip cases are bad in the bag.
    So I am wanting a cell casing to protect the phone when its not in the pouch and just on the table like.
    Points: 20,955, Level: 63
    Level completed: 17%, Points required for next Level: 545
    I got my one off of ebay. Fits good. Only problem is when you need to use the power off and vol buttons, you need to press just behind the mould bit and then all is well Also it feels abit weird when I first used it but ok now and adds little bulk
    Member mazzymon is on a distinguished road mazzymon's Avatar
    newbury
    i also got mine off ebay for £3 same as what doomed said its a about the vol buttons and power but it fits great.
    Vodafone UK
    Points: 2,102, Level: 18
    Level completed: 76%, Points required for next Level: 48
    Kev will become famous soon enough Kev's Avatar
    Northants
    Brought these from Amazon, They both fit perfectly and buttons are easy to use through the Skins.
    The skin helps keep the fone in place on slippery surfaces..
    http://www.amazon.co.uk/gp/product/B...ef=oss_product
    It Would Appear I've Lost My iphone......Again...........Yippi...
