Water damage - Phone displays galaxy screen and thats it. Reflash? - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Results 1 to 10 of 11
Thread: Water damage - Phone displays galaxy screen and thats it. Reflash?
    Points: 459, Level: 7
    Level completed: 59%, Points required for next Level: 41
    Overall activity: 2.0%
    Let it dry out for a few days...
    Powers up as soon as battery is inserted rather than power button. :-(
    Displays Samsung Galaxy, goes blank repeats. If I insert battery while holding vol down/home it displays a strange android triangle icon with downloading....
    Just wondered how I can try to reflash this to fix the problem?
    Or any other suggestions?
    Senior Member Array
    Bring it to the shop?
    Quote Originally Posted by systemX View Post
    Water damage - not covered by warranty.
    Points: 15,015, Level: 53
    Array tiptronic's Avatar
    Bristol, UK
    As long as your phone can start, I don't think they will notice if you not tell
    To go into download mode, you need hold volumne down, home button and power, it sounds like the buttons is contacting the board, perhaps not dry enough?
    Network: O2 UK
    Baseband version: I9100XXLPQ
    Dont all phones these days have water damage indicators placed inside the phone? So they can tell...
    Licking windows
    Points: 4,078, Level: 26
    Level completed: 93%, Points required for next Level: 22
    Overall activity: 13.0%
    Array windowlicker's Avatar
    It might be too late for this, but you should use a desiccant to wick away any leftover moisture. The most convenient choice is uncooked rice. Just leave the phone (and its disconnected battery) submerged in a bowl of rice overnight.
    Samsung Galaxy S ::: Insanity ROM ::: SanDisk 32GB microSD card
    Quote Originally Posted by tiptronic View Post
    So theres no circumstance where the phone starts on its own when the battery is inserted?
    Yeh. Its been in bowl of rice for 2 days since it was dropped in the water...
    Points: 4,914, Level: 29
    Level completed: 72%, Points required for next Level: 86
    Overall activity: 70.0%
    Tagger Second Class7 days registered100 Experience Points250 Experience Points500 Experience Points
    Array spenk's Avatar
    Oxfordshire
    My phone only ever starts when I press and hold the power button for a few seconds. Does it power up immediately on inserting the battery or after a few seconds - may be the power button stuck/water ingress? If you can access compressed air it might be worth giving it a blow - might help remove any moisture in those hard to reach places and remove any rice dust in there
    S3
    Orange Stock Orange ROM
    Quote Originally Posted by spenk View Post
    Im beginning to wonder that button might be stuck/wet. Yes - starts when battery is inserted.
    Wonder if this is why it appears to be constantly restarting? i.e. the power button being on permanently is causing it to reboot.
