Nokia DC-6 car charger - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Nokia DC-6 car charger
    Hi. I need urgently to know if the nokia dc-6 car charger (n97) is compatible with our phone. Thanks
    Licking windows
    Points: 4,078, Level: 26
    Level completed: 93%, Points required for next Level: 22
    Overall activity: 13.0%
    windowlicker is a glorious beacon of light windowlicker is a glorious beacon of light windowlicker is a glorious beacon of light windowlicker is a glorious beacon of light windowlicker is a glorious beacon of light windowlicker is a glorious beacon of light windowlicker's Avatar
    Yes, it is. Works fine for me.
    Samsung Galaxy S ::: Insanity ROM ::: SanDisk 32GB microSD card
    Points: 20,699, Level: 62
    Level completed: 77%, Points required for next Level: 151
    Overall activity: 99.7%
    If it's micro usb it should as they should all be the same standard, not too sure a but really cheap ones though
