Eclipse and Android SDK - Samsung Galaxy S Forums : Galaxy S2 S II Forum
Thread: Eclipse and Android SDK
    Hi all, i am pretty noob at this and never used eclipse although i try to follow the steps in installing the SDK http://developer.android.com/sdk/installing.html.
    I installed JDK and Eclipse and added the ADT to eclipse...so far so good but then in the next step (http://developer.android.com/sdk/ecl...tml#installing) configuring the ADT plugin i go to window preferences i select the Android menu and point to my android SDK directory the thing is when i press apply or ok the SDK never shows in the list below
    First i tried windows 7 x64, JDK x64, eclipse 3.5.2 x64 and thought it some strange 64 bit compability but then i used the x86 (32bit) on all programs except windows and the same thing happens no SDK is added in the list below, i dont get any error or any feedback at all when i press apply.
    Is there something i am missing here?
    Points: 1,123, Level: 13
    Level completed: 16%, Points required for next Level: 127
    7 days registered100 Experience PointsTagger Second Class250 Experience Points31 days registered
    JockyMc will become famous soon enough
    Scotland
    Have you ran the Android SDK setup program first?
    Junior Member Gl1tch is on a distinguished road
    /me slaps Gl1tch around a bit with a large trout
    :S
    Thanks man how did i miss that lolll
